Communicating between CenarioVR and other content
While running, Cenario content detects if it is iframed within another project, for example in a Lectora, Captivate, or Storyline course, and posts messages to its parent detailing what is happening in the content. All messages are posted as JSON, and are indexed by the “type” data member. The following messages are passed:
Messages sent from CenarioVR to its parent Frame
ATTEMPTED
Sent once at the start of a session
- type - cenariovr:attempted
- scenario - (name of scenario)
EXPERIENCED
Sent for each time a scene is visited
- type - cenariovr:experienced
- scene - (name of scene)
- duration - (# of seconds in scene)
CLICKED
Sent each time an object is clicked on in a scene
- type - cenariovr:clicked
- object - (name of object clicked on)
DRAGGED
Sent each time an object is dragged in a scene
- type - cenariovr:dragged
- object - (name of object dragged)
DROPPED
Sent each time an object is dropped in a scene
- type - cenariovr:dropped
- object - (name of object dropped)
- dropzone - (name of dropzone, or not defined for no dropzone)
SPUN
Sent each time an object is spun in a scene
- type - cenariovr:spun
- object - (name of object spun)
ANSWERED
Sent each time a question is answered
- type - cenariovr:answered
- questname- (name of question)
- questtext - (text of question)
- choicetext - (text of selected choice)
- iscorrect - (true or false)
- duration - (# of seconds to answer question)
UPDATED
Sent each time a variable is updated
- type - cenariovr:updated
- variable - (name of variable)
- value - (value of variable)
FINISH
Sent once at the completion of a session
- type - cenariovr:finish
- score - (percentage relative to 100)
- result - (completed,passed,failed)
- duration - (# of seconds to complete scenario)
- variables - (an array of name value pairs)
- name - (name of variable)
Sample JavaScript to catch messages from CenarioVR content
window.addEventListener('message', function(event) {
var data = JSON.parse(event.data);
var messagedatatype = data.type;
if (messagedatatype=='cenariovr:attempted') {
console.log("Scenario Attempted: " + data.scenario);
} else if (messagedatatype=='cenariovr:experienced') {
console.log("Scene Experienced: " + data.scene + ", Duration: " + data.duration );
} else if (messagedatatype=='cenariovr:clicked') {
console.log("Hotspot Clicked: " + data.object );
} else if (messagedatatype=='cenariovr:answered') {
console.log("Question Answered: " + data.questname + ", Correct: " + data.iscorrect + ", Duration: " + data.duration );
} else if (messagedatatype=='cenariovr:updated') {
console.log("Variable Updated: " + data.variable + " : " + data.value );
} else if (messagedatatype=='cenariovr:finish') {
var strVars = "";
for( var index=0; data.variables && index<data.variables.length; index++){
if( index != 0 ) strVars += ", ";
strVars += data.variables[index].name + " = " + data.variables[index].value;
console.log("Scenario Finished: " + data.scenario + ", Score: " + data.score + ", Result: " + data.result + ", Duration: " + data.duration + ", Variables: { " + strVars + " }");
Sending Messages to CenarioVR Content from an Outside Frame
A scenario can also be interacted with from an outside frame by posting messages. Two messages are used, one allows the ability to set a variable's value, the other allows you to run an event, which gives you the ability to perform any action within a scenario. The messages are formatted as follows:
SETVAR
- type - cenariovr:setvar
- value - (value to set)
RUNEVENT
- type - cenariovr:runevent
- event - (name of event)
Sample JavaScript to send messages to CenarioVR content
function setVar(){
window.frames[0].postMessage('{"type":"cenariovr:setvar", "variable":"MyVar","value":"3"}', "*");}
function runEvent(){
window.frames[0].postMessage('{"type":"cenariovr:runevent", "event":"Event1"}', "*");}
This article was last reviewed in October 2024. The software may have changed since the last review. Please visit our Release Notes to learn more about version updates.
