Skip to content
English
Storyline xAPI Process Flow
***All template files are tested using modern browsers, such as Chrome and Firefox. We do not support or test using Internet Explorer.***
Have you watched the xAPI Overview/Setup video for Storyline yet?
For files released April 2019 and older, watch this video»
For files released May 2019 and later, watch this video»
In this video, we're going to take a quick look at how to use the xAPI features in this file.
In addition to the standard Storyline statements that fire in an xAPI publish, we've added some custom statements to give you some deep tracking on your interaction.
The setup is pretty simple really.
In this template, a user clicks one of the primary content buttons on screen, and a statement fires, indicating they did so.
The end result will look like this.
Each of these statements are contextually related to some values you enter for the slide identifier.
This makes them easy to sort and filter, and provides some nice visualization in the analytics dashboard of your LRS.
To use our statements, make sure DISABLE_xAPI is set to FALSE.
Then, enter the details for your slide.
Make sure to check out our xAPI overview video for more details on these details.
Once you edit those values, your file is set up and ready to go.
From here, you'll need to publish and launch your files to see statements.
Check out our "publishing to xAPI" video for more detail.
This article last reviewed Nov, 2018. The software may have changed since the last review.
