Skip to content
English
Submitting Scenario responses - Audio Only
Learn how to respond to an audio-only scenario.
June 1, 2022
  • Under the Assignments tab, you will see Assignments listed in order of soonest due date at the top. Locate the Assignment that you want to work on, then the specific Scenario you would like to respond to. Click once on the Scenario to view.
  • In the Scenario, review the video. You can play the video by clicking on the video thumbnail, or the play button in the lower lefthand corner.
  • Review any text instructions, attachments, and the criteria.
  • Once you are ready to respond, click on Record Response. If you have a response you have already recorded that you would like to upload, click on Upload and follow the prompts.
  • If recording directly through the platform, the recording window will pop up after you click Record Response. Once ready, click on the Start Recording button to begin. When finished recording, click on Stop Recording.
  • Replay your response. If you would like to try again, click on Discard Recording and re-record. You can re-record as many times as you need to. If you want to submit this response, click on Submit Recording.
  • After you click Submit Response, you will see your response populate onto the page with a green background. If needed, you may also add a note to your Mentor by clicking on Add a Note in the lower lefthand corner.
  • To submit another response, scroll to the top of the page and click on the Assignments tab on the left, or Return to Assignments to return to your Assignments list.
