Skip to content
Using Spatial Audio in CenarioVR
You can now activate "Spatial Audio" within your audio objects and place them anywhere within your scene!
Enabling Spatial Audio
When you have inserted an Audio object within CenarioVR, you can click to edit the object. Pictured below, you can now see an option for Spatial Audio, which you can click to enable.
Spatial_v1
Once you have enabled the feature, click "Done" and an audio icon will appear in the scene. From there, you will be able to move the object anywhere within the scene.
Spatial_v2
Volume Levels
You can adjust each audio and video object as needed. The new volume control icon makes fine-tuning much easier. With spatial sound enabled, select the audio object and a volume bar will appear on top of the editor screen. You can also preview the audio sound by clicking on the play button as well.
Spatial_v3
Ambisonic Sound Files
CenarioVR supports Ambisonic Sound Files.  See the following article for more information.
Using Ambisonic Video in CenarioVR (User Guide)
This article last reviewed December 2025. The software may have changed since the last review.
